Mapping Codesys with Sensor through Ethernet I/P
Hi umairyamin,
If the sensor OUT3 and OUT6 signals are Digital Inputs these should correlate to Input Bit2 and Bit5.
Below are the steps to map these values:
I prefer to create Global Variables for easy access across different programs/applications within Codesys.
Step 1: Define Global Variables: BOOL for Digital I/O
Step 2: Map the Global Variable
Step 3: Access Global Variable Ethernet/IP Input within a Program
Hope this helps!
Attached is the demo project.
umairyamin_demo.project (356.2 KB)
Cheers,
Jacob Ball
