I have a PFC 750-8204 controller. Because there is an issue with the controller I am booting from an sd-card. After the boot I want to access the internal flash drive. Is it possible to mount the flash or is there another way to access the flash drive when booted from an sd-card?
The pfc has fixed names, for disks and partitions. e.g.:
/dev/mmcblk1p7. Which is the internal memory’s main partition.
/dev/mmcblk0p2. Which is the SD card’s main partition.
Boot from SD card and login.
mkdir /mnt/internal
mount /dev/mmcblk1p7 /mnt/internal
ls /mnt/internal
The ‘old’ pfc200 has ‘ubi’ / ‘mtd’ flash.
And ubiattach command is needed first.
ubiattach -p /dev/mtd8
mkdir /mnt/ubi0_mtd8
mount -t ubifs ubi0_8 /mnt/ubi0_mtd8
Note of warning: Be extremely careful when handling the internal flash. A corrupt flash destroys the unit!
