How To: Create a self installing SD Card (aka Magic SD)
Steps to create an SD card that when booted, will perform an automatic Firmware Update.
  1. Create a bootable sd-card
    • Using a flashing utility (like Balena or WinDiskImager)
    • Using WBM via Administration>Create Image
  2. Boot the PFC from this sd-card
  3. Shell into the PFC as root user
ssh root@192.168.1.17
  1. Type the following command in the shell:
/etc/init.d/cpsd2intern makelink
Now the SD card will copy itself at every boot into the PFC’s flash!
  1. Power off/on to test the function (with inserted sd-card)
    The progress of firmware update displayed via LED’s U1 to U4
    YELLOW: Copy process is active(approx. 1 minute)
    GREEN: Successfully done!
    RED: Finished with ERROR!
  2. The image is copied into flash. now remove the sd-card and test if the PFC is rebooting from internal flash.
Fantastic Kurt !
Much easier than I thought !
Thanks Kurt, it’s very clear !
Just be careful with this Magic SD if you create an Image with a program which contains Retain Persistent variables.
Sometimes, after PFC reboot (step 6), you will see that Firmware will be updated but program won’t be downloaded.
Indeed I had this problem myself more than once.
Anyone have a script/idea to solve this ?
I only found the best way in that case was to log in the PLC, disable the runtime and do the magic flash.
I used the same workaround as well.
For now, I am used to read/write data in file or database instead of using Retain Persistent variables, as much as possible.
Is it possible to make a self installing SD-card for the BC100?
Normally yes by using the “Enable automatic restore from SD card” from the WBM:
After the PFC copies the image to the internal flash, can I remove the SD card and replace it with a different one to write .CSV files to, or will it try to copy the SD card at every boot?
Since the backup / restore is on the SD card if you use another one it would work like a normal external storage.
only the SD containing the backup will be a program on boot SD card.
Isn’t step 5 a change to the current PFC and not the sc card?
Or can I send this magic sd card to any pfc and update the project, etc?
Only the default firmware image because the PFC100 & 200 share the same firmware image. The PFC300 uses different firmware image.
New tutorial video from Germany on how to set to the Magic SD:
Magic SD card | Saving a controller image to an SD card and AutoCopy it to another controller
