Node-red installation with French wago tutorial Problem with Dockerfile
When using French wago tutorial, they say :
With FTP client WinSCP , import Dockerfile in the folder
/home/docker/mynodered.
What should contain Dockerfile ? , because there is no extension.
I tried with an empty file , but it doesn’t work
The response is Error response from Daemon : The Dockerfile can’t be empty.
What do you suggest to write in that Dockerfile ?
In France there is no support from the differents manufacturers for that kind of things .
Can you give us the link of this tutorial ?
Also have you tried to contact wago france support ?
Hello , it’s a wago french tutorial , made by the wago France in 2022.
If you are interested in , please contact Wago France.
the person that gave me that tutorial said, that they support only
docker setup.
for setup or any question about Nodered , influxdb or grafana they don’t
provide support. (I understand , it’s not their job)
So i hope help with Wago community .
I think good engeneers provide many informations.
but i’m a PLC programmer and not a computer programmer. ( I only
practise C language).
So it’s necessary to have graphic interface with influxdb and grafana
etc… to commission influxdb database , and grafana graphics.
Yesterday I succed in grafana setup and nodered and portainer , but not
at all with influxdb and nodered.
there is a problem with exportintfluxDB.sql that I can’t find .
I 'll post the issue i have, on wago community.
Best regards.
Jean-François Baratte
I setup docker , portainer container , influxdb, grafana , and nodered.
I can launch nodered on port 1880 , but it’s not published, i’ts strange , but it works !
I can’t access to port 8086 for influxdb , but it’s published.
For grafana it’s OK
However, in the list of images, I have the latest versions.
for influxdb, I followed the tutorial to create a database, I manage as in the tutorial to list the users and their rights.
I searched, but I can’t find an exportintfluxDB.sql file in the linux directories of the PFC 8212.
At no time in the tutorial , I found a command to launch an installation of a SQL or sql lite database.
in the documentation, it is requested to retrieve this exportInfluxDB.sql file and to stick it in the ssh editor.
Capture d'écran 2024-11-27 074554
Also if I can’t access influxdb on port 8086, I can’t do anything.
Problem with exportNodered.json files, export grafana.json
Where are they in the linux tree?
even with winscp I can’t find them in the linux directory of the PFC 8212.
i hope someone will help me.
bye
