I’m having an issue where an unhandled exception in the OPC UA server causes the PLC to crash up to several times a day. The appearance of this exception is very inconsistent but from what I can tell it probably has something to do with an unstable network between the PLC and the client.
Any kind of help or input on this issue is greatly appreciated.
Thank you for the quick reply! I will try this new firmware as soon as I get the chance. By looking at the other logs from the PLC I can see similar error messages. I will reply back with results once I’m able to make the update.
I’m using a 8212 as well but with around 800 tags. I have been told that OPC UA works perfectly for other people using thousands of tags though so I’m not sure the issue is with the tag count.
Ever since I set these parameters I have experienced no crashes on the PLC. From my experience a stable network connection is also required. Make sure that your network has no packet loss and there’s enough bandwidth to support the OPC UA server communication.
