PFC200 IO Fault to Ignition Tag
I have a couple PFC200’s that will occasionally go into IO Fault. Still determining the cause, but in the meantime, I would like to alert to the fault in my Ignition system. We are OPCUA connected to these PFC200’s.
Is there a way to write the IO Fault status to a Global Variable?
Thank you
