I am just getting started programming a PFC200v3 (750-8217). One issue that I am encountering is that the PuTTY window keeps closing after around 4 minutes of inactivity. To fix this sort of problem I would normally edit the PuTTY “Connection > Seconds between keepalives” to something like 30, but that doesn’t seem to be working on this occassion. Any suggestions gratefully received.
then reboot ![]()
also if you want to log in without password:
Generate password using PUTTYgen
You can add passphrase, its safer, but you have to enter passphrase each time
Save your private key
In PLC Console (PuTTY) paste and fill file with genereted phrase from “Key” section from puttygen:
mkdir /root/.ssh /
nano /root/.ssh/authorized_keys
To save: CTRL+x, then “y” and enter
- In putty add private key to session:
- Save you session for future use:
