I do not see a cable option in the manual of the 751-9401 or from the Wago website. Does anyone recommend an RJ45 to DB9 CANopen cable? Is there an internal 120 ohm resistor in the PLC for the RJ45 termination?
Hello Barron, We do not have a dedicated RJ45 to DB9 CANopen cable. We do have a CANopen connector that you can use to build your own cable. The part number is 750-963. It does include a 120 ohm resistor that can be enabled or bypassed via the switch on the top of the connector.
Thank you for the reply Stephen!
Hi @Barron ,
there is also another product you can use.
Übergabemodul (289-175/790-108) | WAGO
this allows you to place the termination resistor if the CC100 is the First or Last CAN Participant in the System, a little bit easier.
