Using Codesys 3.5.21.5. Tried installing both by full .exe file and using codesys installer. Installation requires elevation and completes just fine. However when running Codesys and closing the IDE, options-files are not written:
Seems regular users are only given read-access to these files:
Running Codesys as admin works as admins have full access. Haven’t been necessary before to run as admin.
Don’t think I have the issue on my work-laptop, but have experienced this on a number of other computers. Above screenshots are from my private stationary running Windows 11 Pro:
Anyone else experiencing this? Is this by design or a known issue?
Hello, on my part I haven’t seen this error yet.
Since it touch principally codesys itself I don’t think it’s something we can invertigate.
Could you also create a post here:
So codesys people can also check what is happening ?
I have the bad feeling that something have failed during installation and codesys it trying to use the default option instead of the user folders option.
Can you try to reinstall codesys and see if the error persist ?
I have been experiencing the same issue since I updated my CC100 device repository.
I am using the same version of CODESYS (3.5.21.50). I upgraded the CC100 firmware version from 27 to 30 and updated the firmware in the CC10, but since then, creating a new project generates three access errors for the .opt and .project files. It seems that CODESYS cannot find the files, which is surprising since I am still in the project creation phase.
I tried working in administrator mode, but it made no difference.
