I’m encountering an issue while attempting to update the firmware remotely on my Wago PFC 200 via WAGOupload. The SD card becomes locked in read-only file system mode after the update process.
I’ve followed these steps precisely:
- Take the case of a Wago PFC 200 with Firmware 18 (No problems on the SD card).
- Stop the application running on the Wago via E-Cockpit.
- Launch WAGOupload 1.17.10.
- Scan with the Wago’s IP address and connect as root.
- Specify the path to firmware 26.
- Update is complete without any error messages.
- SD card is now locked in read-only file system mode.
The update appears to be successful until the SD card locks itself into read-only mode. This prevents further operations and hinders the functionality of the device.
Has anyone else experienced a similar issue? Any insights or suggestions on resolving this problem would be greatly appreciated.
Additional information:
Wago PFC : 750-8210 PFC-200
SD Card : SD WAGO 8 Go
Firmware 18 to Firmware 26
WAGOupload V 1.17.1.0
Thank you in advance for your assistance.
