SD Card status => CODESYS?
My end goal is to create / trigger an alarm to tell the user there is an issue with controller’s SD Card, because we are writing CSV logs there.
I am worried about a situation where an SD card is not present (or has failed) and we automatically start writing the logs directly to the controller without anyone realizing.
Using a CC100 controller, when I CAA.File.Write to ‘/media/sd/Logs/’ without an SD card, the controller will create a directory locally under that path. This does not cause the File.Write FB to throw an error.
I could probably have Node RED inspect the /proc/mounts file but don’t want to add another layer if I do not need to.
Is there any way for the controller to tell CODESYS if it can see or write to the SD card?
You can use WagoSysFileDir Library to check for a directory on the card.
eSdExist : WagoSysFileDir.eResultCode;
eSysConfigExist: WagoSysFileDir.eResultCode;
eSdExist := CheckDirectoryExists('/media/sd/logs');
eSysConfigExist := CheckDirectoryExists('/media/sd/sysConfig');
myFBConfigTool : FbConfigTool;
sSDresult : STRING(255);
xSDexecute : BOOL := FALSE;
xSDresult : BOOL := FALSE;
IF xSDresult = FALSE THEN
myFbConfigTool( xExecute := xSDexecute, // Start the call once
sCallString := ‘./get_filesystem_data medium-list-json’, // Get the order number of the controller
sResultString => sSDresult // Get the result
IF myFbConfigTool.xDone THEN
	xSDexecute := FALSE;
	IF myFbConfigTool.xError = FALSE THEN
		IF sSDresult = '[ "sd-card", "internal-flash-emmc" ]' THEN
			xSDresult := TRUE;												// SD card inserted
		ELSIF sSDresult = '[ "internal-flash-emmc" ]' THEN
			xSDresult := FALSE;												// No SD card inserted
		END_IF
	END_IF
END_IF
END_IF
The solution MikePsaltis provided does work for my specific situation, but I’ve been using ketan’s solution for the past week and I like it more.
ketan’s solution is more flexible and answers the broad question: “Does the system recognize an SD card?”, and does not depend on the ‘logs’ directory existing.
IF I have an SD card, THEN
I can create the ‘logs’ directory,
and then check if that directory creation step was successful using MikePsaltis’ solution.
Personally I’ve done another solution which is making a symlink:
ln -s /media/sd/ /home/codesys/PlcLogic/sd
This enable me to use the folder /home/codesys/PlcLogic/sd as my SD card and I have an error if it doesn’t exist and the link is broken since it can’t crate the folder.
