Regarding data logging
I’m not able to log data to sd card . an error “status of the last log: file access error” is showing in the data log template. No file is generated in the sd card after trigger is given . is it is the file path issue?
Hi, if you are using Fw26 due to a bug, you need to create the folder yourself.
So by default you have to create the folder CSV_Files in /media/sd/.
hi,
Yes,I m using Fw 26.
The sd card is already inserted in PLC, How can I create folder in the sd card.???
Use an SSH program like PuTTY. The command is “md CSV_Files”, while you are in the “media/sd” folder. For example:
You can use an FTP client such as FileZilla to create and view files. Just don’t forget to enable FTP in the web interface.
i have created CSV_Files , still there is “file access error” is showing.
