Hello all,
In using multicore with the 762-5305/8000-002 I have found that on occasion, the core where a high priority task utilized for ModbusFB is occasionally pegged out. At the time this occurred at core 3 (linux core 2). I have since moved this task to another core and I have not had this issue since. I wondered if this was caused by a conflict in the OPCUA functionality.
I also had an instance where I distributed task across all four cores and the visualization would no longer load. In my testing, none of my task priorities were below 10.
I am curious if there is a linux command prompt command where I could view particular hardware/software functions and at what core they are residing on at a given time, or if there are any further details on this topic than what is attached.
Thank you,
Barron
