Touch panel 600 automatic logint/boot to visualization
Hi all,
I’ve got a Wago PFC200 PLC, connected through an Ethernet cable to a Wago Series 600 touchscreen.
I’m running a web visualization, which I have configured as “Browser Favorites” screens on the touchscreen. Selecting this item works just fine and loads the PLC login screen.
However, I can’t seem to automate opening this screen upon power-up. After applying power to the screen, it boots to a black screen. I can then open the menu by swiping down from the top and open the visualization.
But I can’t find a way to have it open the visualization by default, without me having to open it through the swipe-down menu.
Does somebody know how to achieve this?
What is your TP600 part number ?
If it’s a Visu Panel or Control Panel (/8000-00X at the end), make sure there is no CODESYS or e!COCKPIT program running on the TP600. The TargetVisu (empty) is maybe called on boot up.
Also in the browser favorite have you enable the checkbox “Startpage” to call it on default ?
Sorry for the very late responce, the project was halted for a while.
I have tried checking it as “startpage”, but it still did not start automatically.
The screen is a TP 600 10.1, 0762-5204
Thank you for your help!
What is your firmware version ?
Is there a program loaded in the Visu Panel ?
If there is a TargetVisu it has the priority over the browsers favorites.
You could try to reset the Visu Panel (with e!COCKPIT) or updating the firmware.
