I have Wago 750-880-040-001 models, older models I think. They’re set as the target device on Codesys v2.3, but when I select the device, 104 protocol dissappears and gives an error. How can I fix this? I can’t find the library online. Also, I couldn’t download the old program. In the old program, it was set to 2405, but the addresses are incorrect. I need to find the library and change the 104 addressing. WagoConfigToolLIB.lib error is given by the codesys program. Wago device has another program inside of it but I couldnt taken the program from the codesys.
