This container can be deployed to use the IO points on a WAGO PFC series as remote IO, or used in conjunction with a service like Node-RED for full PLC control functionality (for use with Node-RED we recommend the MQTT-based KBUS API: GitHub - jessejamescox/kbus-api-installer: Install the API to control the the WAGO kbus via MQTT)
Hey community. Any issue running this image on 750-8217 ?
I face an issue :
kbusmodbusslave: error while loading shared libraries: liboms.so.0: cannot open shared object file: No such file or directory
I’ve tried in FW19 and 21 SP2.
One of my colleagues has also tried the IPK directly, without better results.
It looks the liboms library is where it’s supposed to be though…
Thanks for your help.
Quentin
I would try 18, seems 19 and 21 have some missing libraries.
Last version of the image based on FW21 has been published and correct this issue ![]()
