E!Cockpit (Wagosysmodule_75x_65x) (WagoAppcom)
Hi i was having troubles with Modbus RTU, so i did what this page said(8212 with 750-652 modbus trouble) so i downgraded the Lib (everything worked fine). after installing WagoAppCom i get this error "keine Implentierung für Methode ‘_GETDWSWVERSION’ aus schnittstelle ‘I_WAGODMX’ and "keine Implentierung für Methode ‘_GETDIDMXSTARTADRESS’ aus schnittstelle ‘I_WAGODMX’. Any idea how to solve this Problem thanks
Can you post a screenshot of your library manager placeholder?
Something like this:
I know it’s a long list but will help to find what the problem is.
Hello Thank you for your response, here are the pics
i cant uplaod all of them at once because i am a new member.
I think I found the problem. After installing the wagoappcom lib, it automatically downgraded the wagotypescom to v1.6.2.0 which caused an error. I noticed it now and changed wagotypescom to v1.6.1.3 and no more errors. I will try to download it and will let you know. :slight_smile:
It worked. Thank you
