WebGL and TP600 browser
I´m trying to access a service that uses WebGL using a TP600 panel and I just get a message that says “WebGL not supported”. According the TP600 SDK WebGL should be enabled and compiled into the firmware.
Anyone had the same problem and found a workaround ? Running FW24 on the panel.
If I try webglreport.com it gives me the following message (this is the internal browser, I have just enabled the navbar etc):
I don’t know the reason behind.
Results from html5test report that WebGL 1 and 2 are “supported” by the browser.
Full test here : HTML5test - How well does your browser support HTML5?
Yep, very strange. Must be that some configuration of the qtwebengine is missing or some qt components. I’m looking into the TP SDK now to see if I can add something and compile a custom fw.
