Where should application configuration files be stored on WAGO CC100 (751-9402)?
Hi everyone,
On the WAGO CC100 (751-9402) running Linux, which folder or directory in the filesystem is the most appropriate for storing device configuration files for a custom application?
I’m looking for a location that follows good Linux practices and will persist across reboots and updates.
Thanks in advance for any guidance.
I would recommand either /etc/ or /opt/ folder
Thank you for your support!
I will says it depend if codesys should have access to it or not.
For pure linux program, indeed that’s the right answer.
