Storage data on SD card in a cc100
I am a new Wago user and I am trying to create a database on an SD card in a CC100. I have a Siemens PLC sending a DB with some data to my CC100 and I need to create a database capable of storing up to 6 months of this DB. I need to store it on the SD card because I do not have internet access at the location where it will be installed. I have not yet found this topic on the internet to help me. If anyone can help me I am out of ideas on how to proceed.
Hi Engeup,
what is your desired dataformat, do you need human readable data, like CSV or JSON. Or you just want to access the Data via the PLC Code, for example with an ByteArray or an SQLite database.
There are multiple ways, i will show you two and begin with the human readable one:
  1. Store data in the CSV format, with the Wago Lib “wagoappdatalogger”
    You can log up 160 channels, an also confgure those.
    The channels can be saved in an cyclic-interval or you can trigger the writing of data with an event.
You can also download some example projects for this topic:
Beispielprojekte für CODESYS 3 | WAGO Download Center
  1. store the data as bytearray, with the “wagoappfiledir” - Lib
    a) You have to store all data in an datatype, like an userdefined STRUCT or an Array of Byte.
    b) in the picture you can see an example writte in CFC how to read and write the data to the sd card.
Best Regards
Michael
You could move your docker home folder to the SD card, and then pull a database container to host your tables. You might look at influx or mariadb.
Hello Michael,
In this post you mentioned a sqlite database. I know that some of the built in CODESYS features log to a sqlite database (alarm manager, trending, etc). Is it possible to create another sqlite database on the controller for something like an event log?
Thank you,
