750-8112 opc ua problem
Hello, I am trying to connect to UPC but I have not been successful. I am waiting for the right of the structure and help.
If you are using an anonymous connection, you will also need to disable Port Authentication . In the Web Based Management, you can find this checkbox under Configuration → Ports and Services → PLC Runtime Services.
Thank you very mach. Now connection is ok.
