As the subject mentions, I have a Modbus TCP Slave Device (750-362) that has some I/O modules attached to it. The PLC is a BC100 (750-8000). I have setup the communications and I am able to see everything, and all is working as I would expect. I set up the individual modules as I/O channels in the slave setup.
For example, when looking at the local modules I have attached to the PLC, They are added to the K-BUS, and I see each one in the tree. I would like to see the same thing under my Modbus Slave bus coupler. Is this possible? Does something like this exist? This works well, so far and if I were easily satisfied, I would just move on. But, I am always thinking, and was wondering if there as an easier method of adding the IO, as well as more visible.
Thanks
