Iām new to Codesys and I was trying to add the I/O to my program so I can assign it to the variables.
If you are using a PFC or BC100 platform, you can add IO to the Kbus configuration in the device tree. Right click Kbus, and select Add Device.
If you are connected to the controller, you can also scan the Kbus to automatically bring in the IO. You will first need to go Online ā Login. Then you can Logout, and right click Kbus ā Scan for Devices.
