I have bacnet/ip running on this controller. The enet ports on the controller are set to separated. I can scan and discover the device on the wago bacnet configurator software when I look at port x1. When I look at port x2 I can’t discover the pfc200 on wago bacnet configurator. How do I enable port x2 to use bacnet? I can ping port x2 from the machine that I’m running wago bacnet configurator on.
Interesting, Could you send this to WAGO Technical support ?
Are you using FW28 or FW29? If not, I recommend updating the firmware.
