Library "WagoAppPLCInfos_FR.FbSystemInfo"
I have a question regarding the “WagoAppPLCInfos_FR.FbSystemInfo” library in CoDeSys V3.5 SP21 PATCH 3. I am able to add this library and retrieve the PLC information.
However, for CoDeSys V3.5 SP19 PATCH 7, even after adding this library, I encounter library errors. Is there a solution or another library compatible with SP19 PATCH 7 to retrieve this information (firmware version, PLC model, K-bus error code)?
Thank you in advance for your help.
Best regards,
Can you paste information from Messages window?
Hello, thank you for the response: Ultimately, the problem was my working environment, so the issue is resolved.
