Hi all,
I wanted to ask if we can create another username to access the WAGO Screen Touch Panel ? Because the default username password is admin and wago.
Best regards,
Umair
I know for sure that the password can be changed; there are also several users. I have not heard about the creation of new ones.
You can remove authentication and the visualization will be available without a password.
Thanks for the idea. Will try on that.
For accessing the webvisu you can use
admin//your-pw to generally grant access.
If you would like to have a set granular access to certain controls , I suggest you to activate the CODESYS user-management in the Visialization-Manager.
Once activated in the project, you‘ll find additional check boxes in the visu-tool-box properties for every used element.
If I remeber correctly, there Are per default three users: admin, Operator and user.
Great! Thanks for the info. Will try.
