CODESYS error: C0299: Creating a code generator failed: The required plu-in is not installed
I’m attempting to Login to my PFC200 (750-8212) for the first time. I received this error when trying to generate code and login. I tried just generating code and received the same error.
I think I need to install an additional plug in but I’m not sure which one or where to find it. Has anyone else had this issue and been able to solve it?
Are you using BACnet or a Telecontrol protocol (DNP3, IEC61850, etc)? These do require a separate plug-in.
Are you using the built-in WAGO runtime or did you install the “CODESYS Control for PFC200 SL” runtime from CODESYS?
What Firmware does your PFC200 have, and what version of CODESYS do you have installed?
