The AVEVA Edge Data Store (EDS) stores data locally in configurable data storage until it can be sent to permanent storage in a PI System and/or in CONNECT Data services through periodic egress.
Thanks to its 64-bit dual-core processor and 2GB RAM, WAGO’s highly flexible PFC300 removes the need for a separate edge device. The PFC300 allows data to be stored locally at the control level and sent directly to AVEVA CONNECT Data Services and/or the PI System. The PFC300 has enough performance to run both EDS and large CODESYS 3.5 control programs at the same time. The PFC300 is a part of the WAGO 750-series PLC family which offers more than 250 unique I/O modules to choose from.
In my application I used the EDS Built-in OPC UA connectivity. However, EDS can collect data using any of the additional methods: Built-in Modbus TCP connectivity, Custom application using Open Message Format (OMF), Custom application using REST API.
WAGO + EDS Application Overview:
- CODESYS 3.5 runs the control program on the PFC300 and publishes selected variables to the controller’s built-in OPC UA server making them available over the localhost network.
- The OPC UA adapter within EDS connects to the OPC UA server and ingests selected variables using parameters defined in the
.jsonconfiguration file. - EDS stores the ingested data locally, and reliably forwards it to PI and/or CONNECT, creating a fully containerized, real-time data pipeline directly from the PLC.
- Once the data is in AVEVA Data Services it can be visualized or analyzed using the many AVEVA CONNECT services.
The EDS .json file defines:
- The egress targets, including AVEVA PI Server and CONNECT Data Services, with authentication credentials and endpoint URLs.
- Which OPC UA node IDs (variables) to monitor and ingest.
- The local buffering behavior, ensuring data is retained during network loss.
- The schedule and frequency at which data is forwarded to each destination.
- Stream prefixes, namespaces, and filtering rules for organized and efficient data handling.
To learn more about the AVEVA Edge Data Store please refer to their Document website.
