Direct access to IO, via %AT addressing without adding modules to Kbus Codesys V3.5
Hello!
Can I somehow access the inputs/outputs
of I/O modules in Codesys V3.5 Project on PFC200?
Previously I could do this in Codesys V2.3.
If Codesys V3.5 does not have this option, can I add IO modules to the project and disable the “Module Status” check (MS LED on PLC), if the physical number/type of modules does not match the one configured in the project?
Yes, dynamic IO mapping is possible using libraries in Codesys 3.5. Its a little more involved than the way C2.3 did this, but not too bad to learn. Here is a video showing the general idea. The video was using e!COCKPIT, but the C3.5 is basically the same way.
