i am trying to control a Novocon S actuator with a 750-8110 PLC using a 750-652 modul, i used FBMbMasterSerial function block, the Baud rate is set to 9600 in the Modul as well as the Function block, databits is 8 on both, however whenever i run the program in the plc the variable “xIsConnected” is false and it shows an error “Invalid Parameter(s)”. the actuator is functional (configured in Novocon Configuration tool).
does anyone have an idea what can be a solution.
Best Regards,
hades00
Interface of FbMbMasterSerial is
FbMbMasterSerial (FB)
Interface variables
| Scope | Name | Type | Initial | Comment | Inherited from |
| Input | xConnect |
BOOL |
FbBaseInterface | ||
I_Port |
WagoTypesCom.I_WagoSysComBase |
Name of the Interface (e.g. ‘COM1’, ‘SER7.2’, ) | FbBaseInterface | ||
udiBaudrate |
UDINT |
Baudrate (9600 = 9k6) | FbBaseInterface | ||
usiDataBits |
USINT |
Number of Bits per frame (5..8) | FbBaseInterface | ||
eParity |
WagoTypesCom.eTTYParity |
Parity | FbBaseInterface | ||
eStopBits |
WagoTypesCom.eTTYStopBits |
Number of Stop-Bits, see note (1) | FbBaseInterface | ||
eHandshake |
WagoTypesCom.eTTYHandshake |
TYPE of handshake (XON/XOFF, etc) | FbBaseInterface | ||
ePhysical |
WagoTypesCom.eTTYPhysicalLayer |
RS232, RS422, RS485, etc | FbBaseInterface | ||
| Output | xIsConnected |
BOOL |
xError |
BOOL |
FbBaseInterface | |||
oStatus |
WagoSysErrorBase.FbResult |
| Input | eFrameType |
eMbFrameType | eMbFrameType.RTU | ||
tTimeOut |
TIME |
TIME#200ms | |||
| Inout | utQuery |
typMbQuery | |||
xTrigger |
BOOL |
utResponse |
typMbResponse |
where you are see an error “Invalid Parameters”?
