Error message during online change
could someone tell me something about this error message:
Device message: “Alarm online change executed but license for Online Configuration Change not aviable!”
Just last week, I made a program change on this controller (PFC300, FW30) and everything worked fine. The message appears at the end when I perform an online change. Then the controller goes to Stop with an exception error.
What is your codesys version ?
I’m using 3.5.21
This error is also relevant for EdgeController 752-8303 in FW31.
Oh, I’m not the only one receiving this message.
Strangely, this has only happened with this project so far. With other controllers, it works without any issues. My colleague then opened and transferred this exact project from his computer, and it worked. I can’t logically figure out where this error message is coming from.
Anyone having a solution to this?
This error did not appear in FW28 which was the last fw the controller was running on prior to upgrading.
Ensure that “Enable online configuration change” is not enabled on PLC Settings. Configuration changes require additional licensing for online change that is probably not included in the wago codesys license.
This license unlocks the following extended Online Change features:
  • Alarm management
  • Data sources
  • Local I/O configuration
  • PROFINET (Dynamic Reconfiguration)
Code changes, IO-mapping and symbol config changes supports online changes without this enabled.
The specified entry does not exist in the projects.
Manufacturer: WAGO
Categories: Controllers (PLC)
Type: 4096
Version: 6.4.5.11
Order number: 750-8302
Description: WAGO PFC300
2ETH RS
I/O System 750
FW30
Compatible Devices:
750-8302 PFC300 2ETH RS
0750-8302
Additional file: 0750-8302.lic.xml
Not in my installation either.
FW30
