Import of Phoenix PLCNext source code
We are trying to import code from PLCNext from Phoenix to CODESYS V3.5.19.7 Both CODESYS and PLCNext supports PLCOPEN export/import, but so far I get some error messages. There seem to be some differences in the format.
Does anyone have experience with importing code from PLCNEXT using this technique or another way?
Yes, I think this export import use the IEC 61131-10.
This will be enabled in codesys 3.5.21.10 with FW29 (PFC100/200) release soon. or FW30 (release around september).
If you really urgently need to use those import/export, install codesys 3.5.21.10 and enable the IEC 61131-10 export/import function. then use the normal codesys import/export to work with it.
