Increasing memory area 0 in CODESYS 3.5
There are Memory areas 0-2 in CODESYS 3.5, where Memory area 0 is allocated for Data, Input, Output, Code and Nonsafe Data. For PFC200 controller, this Memory area 0 is limited to 62914560 bytes (60 MB). Do you know if it’s possible to increase this Memory area 0 in CODESYS 3.5? There were some functionalities in CODESYS 2.3 that allows user to modify sizes of memory areas
Hi, this is not intended for WAGO devices under CODESYS 3.5
BR
Patrick
Thank you for your response Patrick!
