Does anyone know if there is a Linux command to reset a specific module in KBUS? There are frequent issues with WAGO KNX module during startup and the module seems to get frozen very often. As a first aid, the module reset over KBUS could work. Is there a command that could be used (Linux or WAGO CODESYS library).
Related topics
| Topic | Replies | Views | Activity | |
| Configuration of K-Bus module without using runtime | 1 | 793 | September 20, 2023 | |
| WAGO/pfc-modbus-server: Docker Image to run PFC IO points as Modbus IO | 3 | 633 | June 30, 2022 | |
| Kbus api module unsupported | 1 | 812 | October 19, 2023 | |
| Using SSI module for absolute encoder in NR | 3 | 389 | July 19, 2023 | |
| Warm Resetting and Restarting a Wago PLC via the Reset PB at the Visualization screen | 3 | 315 | May 16, 2025 |
