I am working in a project with Wago 750-8213 and motion Axis LXM28. The communication with drive is OK, but return this fail: “No Softmotion license”.
I already install the licenses in my computer, but don’t fix the fault.
The softmotion license is a runtime license (on the device).
PFC supports only softmotion light.
It can be enabled by a right click on the device / enable Softmotion.
Depending on your application you might need an higher license which unfortunately is not included in the PFC and cannot be installed further, since CODESYS licenses are not compatible with WAGO licenses.
