Reading Serial Number of PFC200 in CodeSys v3.5
Greetings to everyone,
I’m new to this forum and to CodeSys v3.5, and I’m currently working with a WAGO PFC200 PLC.
I need to read the serial number of the PFC200 using Structured Text (ST) in CodeSys v3.5.
I’ve been exploring libraries and functions but haven’t found a clear way to achieve this yet.
Any help would be greatly appreciated.
Thank you in advance!
You can use the WagoAppConfigtool, and call the following script :
./get_coupler_details serial-number
Thank you for your response!
I appreciate your suggestion to use the WagoAppConfigtool and the script ./get_coupler_details serial-number.
However, if there’s an alternative way to retrieve the serial number directly in ST without using scripting, I would be very interested to know about it.
Thank you again for your help and guidance!
Here is a snippet based on SysTarget library.
Note that it will return a serial number based on MAC-address (i.e 0030DE507951), not the same result as WagoAppConfigtool library (i.e 7SUN31564010260430577+0000000000003772)
PROGRAM POU
Result: SysTarget.RTS_IEC_RESULT;
psSN: POINTER TO STRING(255);
sSN : STRING(255);
maxLen: DINT := 255;
//Required Libs: SysTarget
IF psSN = 0 THEN
Result := SysTarget.SysTargetGetSerialNumber(ADR(psSN),ADR(maxLen));
END_IF
sSN := psSN^;
@quenorha thank you so much for your response!
Your advice has been very helpful and has given me a clearer direction on this. :blush:
Thanks again for your support!
I tried calling two methods and they worked.
Question: where did I write the serial number on the PLC itself?
As I understand it, the MAC address is somehow related to the serial number?
0030DE507951 = 7S UN315640102 60430577 + 0000000000003772 ?
