Hi, I’m struggling with saving a file using the CAA File library. When I open a file for writing/creating a file, I get “access denied” information. The question is, what permissions should I log in with (I log in with “admin”) to have writing access?
file access is restricted to the SD card and the path A:\plc and of course to other folders below A:\plc. The csv folder should therefore be created in the A:\plc folder.
ok,
Thanks, I will try to use this folder and let you know.
BTW, I tried also to use panel TP600 (762-4203) as an SFTP destination for writing a file. I used a path:
sFileName: STRING:=‘sftp://:@<192.168.1.3>[:<22>]/home/user/Test.txt’;
also with the same result as with BC100.
Is it the correct path?
First check the folder exist.
Next be sure the login you are using can write in this folder.
You can easily check by using a SSH client, using the same login to connect to the device and using nano or vi to create the file.
