I am trying to enable remote syslog on pfc/edge/tp but I am not able to get this to work.
Tried to add one of these to the /etc/syslog-ng.conf without any success.
destination remote { network("ip-of-syslog-server" transport("udp") port(514)); };
destination remote { udp("ip-of-syslog-server" port(514)); };
Anyone that got this working on the WAGO controllers?
I use successfuly this one :
destination d_syslogserver {
syslog("ip-of-syslog-server" transport("tcp") port(514) );
(I think udp can be used as well. )
Then you need to add this one also :
log {
source(s_local);
destination(d_syslogserver );
Then restart the syslog
/etc/init.d/syslog-ng restart
Take a look to /var/log/syslog-ng.log to see if there is a problem.
Found some tutorials so I got it working. It was the the second log part I was missing
Tested it with udp and it works as well.
Thanx!
Yes, you can also add some filtering and parsing between the source and the destination.
