I use a lot of 750-658 Can card or 750-652 RS com card in XTR version.
I’ve never found a sturdy, small, industrial-grade 120-ohm resistor that can be mounted directly on the card
I’m looking for resistors that don’t stand out when you open the electrical cabinet.
Any idea?
Regards
WAGO has empty component housings that will plug into standard terminal blocks. You can insert a resistor into the housing and then push it into place in the terminal block inside your cabinet.
Thanks Adam. It is a good idea
