Using MemCopySecure in CFC editor
Hi.
I’m trying to use MemCopySecure from WagoSysPlainMem the in the CFC editor, and I’m faced with an issue. When compiling, I get the following error:
[ERROR] Too few outputs exixts for the box ‘MemCopySecure’ (minimum is 1).
I’ve been able to work around this by triggering it in an action, but that’s a little bit cumbersome. Is there any other way to get it working?
Hello sommerz,
unfortunately, CFC always requires functions with a return value, so your workaround is correct. There is no other option in the CFC editor. Alternatively, you can work with a different implementation language.
Hi Florian,
thank you for the feedback.
I guess another option would be to write a function block in ST that implements MemCopySecure, but adds a dummy output to make it work in CFC.
Merry Christmas.
