hi,
i am trying to upgrade a brand new wago cc100 0751-4903 (dali version).
considering that the ui of the webconfig is a horrible mess where i can barely find any settings and even when i do the well established industry standard expressions like “FIRMWARE UPDATE CLICK HERE DUMMY” are reinvented to some mumbo jumbo wordings, i tried to upgrade the firmware from 04.06.07 (28) to 04.08.09, downloaded from the amazing download center fails via the wagoupload (1.18.0.0) at 78% no matter what i do with it.
i even tried the sd card method who’s description is typical cryptic few word salad.
here is the logfile, i am trying to upload it via the usbc port with the default 192.168.42.42 ip.
Jun 2 05:11:52 CC100-6ABBA8 fwupdate_mode [3559] [Info]: Reset information for WAGO Firmware Update
Jun 2 05:11:56 CC100-6ABBA8 fwupdate_mode [3559] [Info]: Activate WAGO Firmware Update in system1
Jun 2 05:11:59 CC100-6ABBA8 fwupdate_background_service [3910] [Info]: Check-System stopped
Jun 2 05:12:00 CC100-6ABBA8 fwupdate_background_service [3910] [Info]: Runtime stopped
Jun 2 05:12:02 CC100-6ABBA8 fwupdate_background_service [4079] [Info]: Started fwupdate timeout watcher with timeout=1799s, PIDs: 4079 4112
Jun 2 05:13:35 CC100-6ABBA8 fwupdate_control [4273] [Info]: Start WAGO Firmware Update
Jun 2 05:13:35 CC100-6ABBA8 fwupdate_control [4273] [Info]: Using RAUC file “/tmp/fwupdate/update_30_040809.raucb” for update
Jun 2 05:13:36 CC100-6ABBA8 fwupdate_control [4273] [Info]: Stop fwupdate timeout watcher with PIDs: 4079 4112
Jun 2 05:13:38 CC100-6ABBA8 fwupdate_background_service [4373] [Info]: Docker stopped
Jun 2 05:14:14 CC100-6ABBA8 fwupdate_background_service [4373] [Info]: Target firmware version: 04.08.09(30)
Jun 2 05:14:24 CC100-6ABBA8 fwupdate:hooks.sh [5321] [Info]: Call for hook “slot-pre-install” of slot “rootfs.2” (slot class “rootfs”)
Jun 2 05:14:24 CC100-6ABBA8 fwupdate:hooks.sh [5321] [Info]: Start root file system pre-installation hook
Jun 2 05:14:24 CC100-6ABBA8 fwupdate:hooks.sh [5321] [Info]: Run settings backup
Jun 2 05:14:24 CC100-6ABBA8 fwupdate:hooks.sh [5321] [Info]: Save settings
Jun 2 05:14:54 CC100-6ABBA8 fwupdate:settings_backup_store [5404] [Info]: Setting backup is done, “0” backup error(s) found
Jun 2 05:14:54 CC100-6ABBA8 fwupdate:hooks.sh [5321] [Info]: Hook “slot-pre-install” of slot “rootfs.2” (slot class “rootfs”) has finished
Jun 2 05:15:48 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Call for hook “slot-post-install” of slot “rootfs.2” (slot class “rootfs”)
Jun 2 05:15:48 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Start root file system post-installation hook
Jun 2 05:15:48 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Persist settings for new firmware
Jun 2 05:15:48 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Save original settings file “/tmp/fwupdate/fwupdate-settings.cfg”
Jun 2 05:15:49 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Save original account files “/tmp/fwupdate/fwupdate-accounts”
Jun 2 05:15:49 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Enable WAGO Firmware Update autostart in new firmware
Jun 2 05:15:49 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Disable runtime autostart in new firmware
Jun 2 05:15:49 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Disable finalize_root in new firmware
Jun 2 05:15:49 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Synchronize active runtime version
Jun 2 05:15:49 CC100-6ABBA8 fwupdate:hooks.sh [8529] [Info]: Hook “slot-post-install” of slot “rootfs.2” (slot class “rootfs”) has finished
Jun 2 05:15:51 CC100-6ABBA8 fwupdate:hooks.sh [8588] [Info]: Call for hook “slot-install” of slot “home.0” (slot class “home”)
Jun 2 05:15:51 CC100-6ABBA8 fwupdate:hooks.sh [8588] [Info]: Start home migration hook
Jun 2 05:15:52 CC100-6ABBA8 fwupdate:hooks.sh [8588] [Info]: Format inactive home device “/dev/mmcblk1p7” (ext4)
Jun 2 05:15:54 CC100-6ABBA8 fwupdate:hooks.sh [8588] [Info]: Migrating home done
Jun 2 05:15:54 CC100-6ABBA8 fwupdate:hooks.sh [8588] [Info]: Hook “slot-install” of slot “home.0” (slot class “home”) has finished
Jun 2 05:15:55 CC100-6ABBA8 fwupdate:hooks.sh [8747] [Info]: Call for hook “slot-install” of slot “bootloader.0” (slot class “bootloader”)
Jun 2 05:15:55 CC100-6ABBA8 fwupdate:hooks.sh [8747] [Info]: Start bootloader installation hook
Jun 2 05:15:57 CC100-6ABBA8 fwupdate:hooks.sh [8747] [Info]: Setting bootloader version to 99…
Jun 2 05:15:57 CC100-6ABBA8 fwupdate:hooks.sh [8747] [Info]: Bootloader installation done
Jun 2 05:15:57 CC100-6ABBA8 fwupdate:hooks.sh [8747] [Info]: Hook “slot-install” of slot “bootloader.0” (slot class “bootloader”) has finished
Jun 2 05:15:59 CC100-6ABBA8 fwupdate_background_service [4373] [Info]: Update partition labels for system number 2
Jun 2 05:16:05 CC100-6ABBA8 fwupdate_background_service [4373] [Info]: Rebooting from rootfs.1 to rootfs.2…
Jun 2 04:17:19 CC100-6ABBA8 S15_fwupdate_service [1070] [Info]: WAGO Firmware Update active, try to continue update operations
Jun 2 04:17:19 CC100-6ABBA8 S15_fwupdate_service [1070] [Info]: Wait for default/factory settings have been created (timeout 60s)
Jun 2 04:17:50 CC100-6ABBA8 S15_fwupdate_service [1070] [Info]: Restore account settings from “/settings/fwupdate-accounts”
Jun 2 04:18:04 CC100-6ABBA8 S15_fwupdate_service [1070] [Info]: Restore settings from “/settings/fwupdate-settings.cfg”
Jun 2 04:19:33 CC100-6ABBA8 S15_fwupdate_servicesettings_backup_restore [4226] [Error]: [missing parameter] : “webserver-certificate”
Jun 2 04:19:36 CC100-6ABBA8 S15_fwupdate_servicesettings_backup_restore [4226] [Error]: [unknown error (1)] Failed to restore parameter: “snmp-v1-v2-state” “invalid command line: enabled”
Jun 2 04:19:36 CC100-6ABBA8 S15_fwupdate_servicesettings_backup_restore [4226] [Error]: [unknown error (1)] Failed to restore parameter: “snmp-v1-v2-community-name” “invalid command line: public”
Jun 2 05:20:00 CC100-6ABBA8 S15_fwupdate_servicesettings_backup_restore [4226] [Error]: [content of config file is inconsistent] Failed to run modular restore script: “/etc/config-tools/backup-restore/backup_oms_mode”
Jun 2 05:20:10 CC100-6ABBA8 S15_fwupdate_servicesettings_backup_restore [4226] [Error]: [internal error] Failed to run modular restore script: “/etc/config-tools/backup-restore/parameter_service” “Invalid value for parameter “cors-policy””
Jun 2 05:20:10 CC100-6ABBA8 S15_fwupdate_servicesettings_backup_restore [4226] [Info]: “5” restore error(s) found
Jun 2 05:20:11 CC100-6ABBA8 S15_fwupdate_service [1070] [Info]: Rebooting from rootfs.2 to rootfs.2…
Jun 2 05:21:05 CC100-6ABBA8 S15_fwupdate_service [1064] [Info]: WAGO Firmware Update active, try to continue update operations
Jun 2 05:21:07 CC100-6ABBA8 S15_fwupdate_service [1064] [Info]: Started selftest of WAGO Firmware Update
Jun 2 05:21:07 CC100-6ABBA8 S15_fwupdate_service [1064] [Info]: Selftest of WAGO Firmware Update successful
Jun 2 05:21:09 CC100-6ABBA8 fwupdate_background_service [1465] [Info]: Started fwupdate timeout watcher with timeout=599s, PIDs: 1465 1493
Jun 2 05:31:08 CC100-6ABBA8 fwupdate_background_service [1465] [Info]: Stop fwupdate timeout watcher with PIDs: 1465 1493
Jun 2 05:31:08 CC100-6ABBA8 fwupdate_background_service [1465] [Info]: Got cancel request (1000) in state: unconfirmed, sub-state: global
Jun 2 05:31:10 CC100-6ABBA8 fwupdate_background_service [3559] [Info]: Start rollback
Jun 2 05:31:11 CC100-6ABBA8 fwupdate_background_service [3559] [Info]: Call bootloader backup installation
Jun 2 05:31:12 CC100-6ABBA8 fwupdate_background_service [3559] [Info]: Setting bootloader version to 99…
Jun 2 05:31:12 CC100-6ABBA8 fwupdate_background_service [3559] [Info]: Bootloader backup installation done
Jun 2 05:31:16 CC100-6ABBA8 fwupdate_background_service [3559] [Info]: Trying to mark slot “booted” as “bad”
Jun 2 05:31:18 CC100-6ABBA8 fwupdate_background_service [3559] [Info]: Marking slot “booted” as “bad” done
Jun 2 05:31:19 CC100-6ABBA8 fwupdate_background_service [3559] [Info]: Rebooting from rootfs.2 to rootfs.1…
Jun 2 05:32:07 CC100-6ABBA8 S15_fwupdate_service [933] [Info]: WAGO Firmware Update active, cancellation in progress
Jun 2 05:32:10 CC100-6ABBA8 S15_fwupdate_service [933] [Info]: Rollback finished
i am working in industrial automation for the past 15 years and i havent seen a product this poorly documented.
yes this is a rant, i recommended a ton of this it as a cost-effective solution for a dali project and now they arrived and i have to waste my time with this.
