I am currently using a WAGO PFC200 750-8110 for data monitoring and sending data to the cloud through an AWS MQTT broker (Connection 1).
I now have a requirement to send the same data to another MQTT broker (Connection 2) simultaneously.
My question is:
- Is it possible to establish two MQTT broker connections on the 750-8110 without purchasing the Multi Connectivity license?
- Can this be achieved using available CODESYS libraries / MQTT libraries instead of the licensed WAGO Multi Connectivity functionality?
- If yes, could someone please share an example implementation or sample Structured Text (ST) code for maintaining two MQTT connections and publishing data to both brokers?
For example:
PFC 750-8110 → MQTT Connection 1 → AWS Broker
PFC 750-8110 → MQTT Connection 2 → Second MQTT Broker
Any guidance, library recommendations, or working code examples would be highly appreciated.
