I upgraded my panel to Firmware WP400 4.8.9(30).
But still I have problem with the keyboard not showing when I should write inn login name and password.
It works the first time but not after some time.
It’s on WBM config and the keycloak login.
Do somebody know if this is something wago is working on?
Hello I haven’t touch it for a while but can you try if those problem also happened with the FW28 ?
I know going back a FW version is not the best answer but it may be a possibility of a regression.
I have had the same problem all the time, so the old Firmware had it to.
Wago is sending me a new hardware version, this was one of the first in Norway, so it has been some hardware upgrades as I understood it.
