752-8303/8000-002 using CNC function
The customer wants to build a simplified CNC with four servo axes using the Edge Controller 752-8303/8000-002 with EtherCAT master (I suggest using EtherCAT for speed).
Has anyone used the CNC or SoftMotion libraries in Codesys 3.5 with Wago Edge Controller or pLCs?
A program example would be great.
Thank you in advance.
Carlos Pena
Since Softmachine requires license (except Softmotion Light maybe) and Softcontainer is not supported on WAGO’s runtime, you need to use a runtime from CODESYS.
Either run Linux SL or Virtual Control SL one the device.
