Using a 750-8000 in Codesys 3.5 but current version description package from download center (2.0.4.4) does not contain one nor is it mentioned anywhere in the release notes. Webpage for 750-8000 suggests it uses Codesys 3.5 for programming but does not list the separate description file like other models.
Is there a description file for this device somewhere?
Thanks, that worked. Although still can’t find it in download center outside of that link.
I’m finding conflicting information on Ethernet/IP support with the BC100. It does not build with an E/IP scanner in the project (Replacing a CC100 due to 0-10V inputs), but E/IP support is listed in many places. Does it only support being an Adapter?
Ethernet/IP scanner and adapter will be supported in FW04
Thanks for confirming, is there a timeline for that release?
