Hello Community,
I recently created a fresh VM, and installed CODESYS SP19 Patch 2. I wanted to be able to use this installation with previous FW versions that are not included in the v2.0.4.2 (FW26) WAGO Device Description. After installing v2.0.4.2 I was unable to install previous Device Descriptions and saw this message in the CODESYS Installer:
" The packages which should be installed are already installed in the target installation"
In order to use this CODESYS installation with previous FW versions I completed these steps:
- CODESYS Installer - Uninstall Device Description v2.0.4.2
- CODESYS Installer - Install Device Description CODESYS v2.0.1.7
- CODESYS Installer - Install Device Description CODESYS v2.0.2.9 (Updates and adds to previous)
- CODESYS Installer - Install Device Description CODESYS v2.0.4.2 (Updates and adds to previous)
I can use previous firmware with this installation.
