EtherCAT EoE configuration on CC100 with CODESYS 3.5
EtherCAT EOE configuration on CC100 with CODESYS.pdf (2.0 MB)
The attached document explains how to use EtherCAT EoE on the CC100 with CODESYS 3.5.
EoE stands for Ethernet over EtherCAT and is required to run TCP/IP protocols over the EtherCAT fieldbus. For example, TCP/IP is needed to view the Web Base Management System of the slave device, update the firmware, or run the IO-Link Configuration Tool.
