FbSmtpSendMail_sMessage
Hello all,
Wondering if it’s possible to make this code smoother (fewer operations)? I’m not a expert on structured text.
Want to create a multi-line STRING on ‘sMessage’, and also add a value from a variable somewhere in the line.
Best regards
Rune
There are three options with WagoAppString library, where you can find functions also for strings longer than 255 characters:
  • Concat3…9.
  • Format1…9
  • StrAppend
Here is example of usage of StrAppend function:
   sBuffer : String(1024);
sBuffer:='';
StrAppend(sBuffer,SizeOf(sBuffer), 'Temperature:');
StrAppend(sBuffer,SizeOf(sBuffer), ' ');
StrAppend(sBuffer,SizeOf(sBuffer), TO_STRING(rTemperatureVariable));
StrAppend(sBuffer,SizeOf(sBuffer), '°C');
Thnx for the advice, Damian.
That’s solved the case.
/Rune
