I succeeded several months ago to install tailscale on a PFC8212 with FW 28
I changed the FW to 30.
I tried to install again tailscale , but it seems that there is not enough space.
Do you know what the directories I have to clear ?
to check left space on the plc you can use command:
df -h
Updating the firmware might have wiped out your DNS settings. If you can ping ‘8.8.8.8’ but can’t ping ‘www.google.com’, for example, you need to reassign a DNS in the Web-Based Management.
Thank you Adam,
it works.
i’ve installed tailscale on the PFC , and now it’s possible to remote program the pfc , using a 4G modem.
I would like to explore the subnet tailscale function , to see the other IP PLC (other trademarks than Wago) on the same local network, to check the data transfer between PLC .
all the videos and tutorial are pretty complicated.
Do you know a website that explain that simply ?
I succeeded to commission a subnet of the remoted PFC200.
It’s a great tool.
