Hi
I am trying use the Codesys Communication Manager to set up an Opc ua server with a custom information model. As a start I am using the Boiler model available on Opc foundations github page.
I am testing with a Wago CC100 and using Codesys V3.5 SP19 Patch 6.
I get the following error:
Communication Manager [Device: PLC Logic: Application]: The information model http://opcfoundation.org/UA/ is required by http://opcfoundation.org/UA/Boiler/ with a minimal publication date from 15/12/2023 but the device has only a model from 15/09/2021 installed. Probably the information model from 15/09/2021 is missing in the information model repository.
The error message does not make sense to me. Should it not be “Probably the information model from 15/12/2023 is missing in the information model repository”?
Anyway, both versions are available in the repository. How to fix?
